mrmister001
Hi, I just bought an Android phone with KitKat 4.4.2 from Hanspree manufacturer, model SN50MC1 and although the phone has a lot of free space inside, incredibly I have almost no space to install applications.
The Hannspree SN50MC is partitioned as follows:
sdcard0 (This is an external SD card I have installed on the phone) which space is 14 GB
sdcard1 (internal phone storage) and it is divided into 2 partitions, one is sdcard1 that has 11 GB free ... and the other partition / device has 2 GB free
When I install applications they go to / device, so it is like if the phone had only 2 GB of internal memory for applications, because applications go all there. The other 11 GB are not used by the applications...
I'm wondering why the Hanspree Enginers partitioned the phone so bad !!! perhaps they thought people would install just 4 cool apps, and they only would need just 2 GB (sad) and the other 11 GB for cool pictures from the family...
The thing is... if I decide to move the apps to the external SD card (which it is sdcard0) ... actually I can move the apps to this place and I see how the space from the partition / device 2 GB is released and then I see how sdcard0 occupy more space but as the internal partition / device 2 GB is so small, even if I move apps to the external card sdcard0, what happens is that some of the data will always remain in this partition / device 2 GB and increasingly I get less and less space, so I have a new phone that has plenty of space on all places except in the internal partition, and although I have a lot of space, I can not install more applications because I'm being very limited
This never happen with Huawei.
In Huawei, the internal partition is unique, no segmented into parts. Only one partition, called internal memory and it has all the internal memory of the device, about 14 GB free. The result is a wonderful phone in which you can install hundreds of applications without being limited by space.
In Hanspree I have a "hot potato", a quick phone with 8 cores that have space on all places, but that has no space for applications.
Any solution?
Cheers
Any solution?
Cheers
