Root [ALPHA] HDCA9100 ROM working with MMX A75
ANOOPPA
Member
Wow....in specs....its a match except for the ram, screen resolution and gpu frequency. Care to give us any screeshots of your phone buddy? :)
UI is pretty much same (except a flickering status bar) that you see in that video. You may have to edit SystemUI.apk to fix status bar issue.
BTW if you have half an hour of free time you can try out this rom .
steps.
1. Install CWM recovery V1 by varun.
2. Copy this zip file to sdcard.
3. Boot in to CWM recovery
4. Backup existing ROM
5. Install zip from Sdcard
6. Fix permission
7. Reboot system.
Note: Initial boot may take few minutes.
Thanks
Anoop
I tried it but d display was weird going out of screen cos of which was unable to use it as everything was out of screen.
