TRICKorDEVICE
I don't really want to have to return the whole phone. Please post how you fixed yours.
I put the black/grey rubber case from AT&T on mine and haven't noticed any creaking since.
had the same problem. took it to the at&t store where i purchased it. they did not acknowledge the issue as it was not a "real" hardware problem that is hampering the working of the phone. called up customer service and they told me to take it to another store. they swapped the back cover for me and was out in two minutes.
Thats what she saidMines very tight...
I've played with several Atrix. Slight creakiness seems to develop and I think is unavoidable. It will feel very tight at times, but will inevitably give in to some play at other times. If you're sitting there squeezing every side of the phone looking for a creak, you're going to find one. Using small pieces of scotch tape can alleviate the problem.
LOL.
Seriously, though. I think there is a TINY bit of creakiness in every Atrix. It's in the DNA.
I put a folded up piece of paper on top of the battery, in between it and the back door on my EVO. It takes up the little bit of play making the creak.
I took the back off and inspected it closely, one of the tiny pieces that locked in was slightly bent, I straightened it out and now it seems much better. I will likely not be taking this one back.
That said, please describe how you apply the tape, sounds like a reasonable solution.
