Help Alternate lock screen?
xkingofgodzx
Is there a way to change the slide to unlock on the Inc? I really like the one on the droid and other Android devices. The one on the Inc is alright but i like the droids better. Is it possible without rooting the device?
lockbot pro. make sure you check "use full screen" in the options or you can pull down the notification bar
