hannahl3
Theres a buzz going around at the moment in this forum whereby any faults in the phone may be caused by a task killer. I in fact removed mine in order to do some experimenting with various faults that my phone had developed, but this obviously means that lots of stuff now runs in the background without me noticing it, a prime example being that my ringtone app turns on every time the phone rings.
So - without the aid of a task killer or a safety net, how can you find out whats running on stealth and whats the best way to turn these off without going into file manager folders and hoping that the phone doesnt ring before you finished?
I don't know whether it lives up to it's name but by closing everything you are hurting your phone performance. A task killer should only be use very sparingly for the odd app that causes lag issues that you cannot do without.
