Help Always in silent mode...
My LG Esteem is NOT in Silent Mode, however, whenever someone calls, the phone magically enters silent mode. (therefore, I do not hear my ringtone and miss a lot of calls) After they hang up, or I hang up, the phone exits silent mode. But then the above happens, obviously. If I exit Silent Mode while in the call, the phone will continue to do all of what I've just described anyway. It's pretty annoying...
I have the plague kernel installed (extreme 2ghz one, but it's not the kernel as this has been happening since before cwm was even released for this phone.) I'm not sure if it started happening before or after I rooted it though.
Yup, it's not...It's set to Anticipation. When a call comes in, and during the call I can see the silent mode icon at the top bar.
i used to have the same problem, i erased the call blocker that i had installed and it hasnt happened since. If you do have a caller blocker app installed I heard that many dont want to work on the esteem. hope that helps
no it was Call Control-Call Blocker. But I had heard that many call block apps did not want to work with the Esteem.
