Root am i bricked.. help
wwalding
I used odin to install stock gb Rom Now it just boots to galaxy s i9000 to a loading screen with lots of err are reboot, wipe data cache. Insta Anytime i click on any options it go exclamation screen. I can not get load screen. To install an odin tar. doesn't recognize it when plugged suggestion?
http://db.tt/eFxMHjD
Well if you can get into downloading mode you can possibly try the one click Odin with jf 6 back to 2.1. If that doesn't work then i dont know what will.
