I might just be crazy but... When I plug my Captivate into either a powered usb hub OR directly to my computer it seems like its draining the battery... To make sure it wasn't the cable (which I got at MonoPrice) I took the supplied power wallwart and used that with the cable I got from MonoPrice and it charges fine.
100% charge... connected to hub/pc... 20 minutes later is down by 20%.
Same USB cable but now using the wallwart... 30 minutes later goes from 6% to 29%.
Is there an easy way to see what kind of power the USB connections are putting out? I have a little Radio Shack multimeter but I've only ever used it to to test conductivity, pin outs on "odd" cables and checking the charge on batteries.
Thanks in advance!
Thanks in advance!
