Root ??? Am I rooted?
C3Pdr0id
Member
I rooted my phone, tested it with root checker & it passed.
I tried to open Titanium & it "couldn't acquire root access"?
any ideas?
Did you click the "problems" button in titanium? Have you tried any other root only apps?
Titanium Backup just displays "Asking for root rights..." & the circle at the top just keeps spinning.
At one point weeks ago it worked, I was cleaning the dalvik cache
I tried Andromizer & it does nothing.
Last resort would be to reset to factory (hard reset) & go from there.....
Trying to avoid the nuclear option but it's always on the table, lol
if this were to happen in the future I'd like to know if a file is corrupting - if anyone else has experienced this (from search it shows this to be the case- but no real solutions) & what happened to cause it & how they fixed it
Have you tried clearing the cache/data on the Super User app? It has worked for me in similar situations in the past.
Also worth checking to see if USB Debugging is enabled, I know TB can play funny if that's not enabled.
Thanks for the help so far
debugging is enabled
it's simply not rooted anymore it looks like??
I tried it again yesterday & reverted to the default carrier's wallpaper
edit: I went into SU & couldn't find anywhere to clear the cache?
see all my screen shots once I add them....
ok, I'm not rooted anymore & am stumped as to how but here's the proof in the pudding I think:
so time to start over.
I'm befuddled because yesterday is when I tried to root again to download a helper file so I could make a gps switch via the app Macrodroid
I was confused why the helper file would not DL, the developer told me it's because I wasn't rooted. W/O root scripts & helper files can't be DL'd.
That's when I tried to root again & the carrier wallpaper appeared AND the helper file DL'd............
Alright, I think I know what your issue is. The problem is that you made a very common mistake when rooting the Hydro/Rise. There is a specific version of su/superuser that works, and it looks like you used the latest version of the rooting script.
Easy Fix:
Open Superuser, set grant root access to allow, prompting does not work, will refuse root every time because of it.
Not-So-Easy Fix:
You need to remove superuser and SuperSU. Having both on your phone anyway is a good way to ruin your root access.
After removing them, you need to re-root with the correct rooting script.
[GUIDE] Root your Kyocera Rise! - Android Forums at AndroidCentral.com
Note to Everybody:
If anybody asks how to root the Rise/Hydro, please send them to this link.
Wow, easy method worked like a charm!!
Makes sense why it was just waiting spinning, it was stuck at the prompt.
Thanks a ton!
cooldudezach you are a cooldude, I'll vouch to that, lol
Thank you to all who helped me avoid the nuclear option ;)
Thanks a ton!
did you reroot the phone, or set it to always allow?
