Root Am I Screwed?
Unit
So I updated to ZVD, Could not root it for some reason and I was doing everything right, It kept saying "adb not reconized" So i used LGSPT or something like that to go back to ZVB, The Installation froze at 59 Percent, but still kept downloading so now i boot it up, and it just goes into a android and a box for 2 seconds and reboots over.. & Over.. & Over.. No cwm or anything since i upgraded to ZVD, Am I Screwed having noway possible to fix this myself?
sound like you wiped the OS out, have you retried installing the zvb back on with that tool? have you tried hard resetting?
Updating my phone then call me..will pm you when my phone is done ok:confused:
If it boots up there IS a way to fix it-Its what we do on here "Get It Done"
Try this:
This is what I did Press and hold both the volume keys. Then hit the power key as soon as you feel it vibrate let go of ONLY THE POWER KEY still holding the volume keys Then a menu will come up and ask to erase all data hit the power key to confirm and it should reboot into recovery! Hope this helps anyone having the same problem.:eek:
http://androidforums.com/esteem-all-things-root/513099-stuck-boot-loop-not-cwm-boot-loop.html
http://androidforums.com/esteem-all-things-root/513063-i-need-help-d.html Sense you don't have cwm this might help too
Got it guys! Had to reboot my computer like 4 times for some reason to get LGSPT past 67% (?)
But finally got it to ZVB, Then went back to ZVD just because it just seems the best thing to stay with. Freakin feel like im ADD-ish -.-
Thanks guys!
Thanks guys!
Sweet!:D
Thanks guys!
good job... pats you on head
Thanks guys!
YESSS:thumbup::D
