Amazon Appstore Not Installing
Shmooey
I have the apk downloaded and when i click on it to install it it'll act like its installing and then say "application not installed". How does one fix this?
Dang. :(
Ok, the usual questions - phone model, how much free space for apps, did you get it from Amazon, you know, the usual dumb questions, sorry. Also important, does your phone use an actual sd card, and has it given you any grief lately?
And just thought - I'd had the old one to install. They had an update recently, hope that installer isn't wonky.
Anyway, shoot me back some info, let's see what we come up with.
Alright, here we go
Model - HTC Evo 4G
Free Space - At the moment 345 mb
I got it from Amazons website
My phone does use an actual sd card and it hasnt given me any problems lately (or at all really)
Ok, great phone btw, I rocked one for a long time.
The Amazon app is among the larger ones out there at 18 MB (it's in the top 5 of my apps) but you have enough storage. You got that number from app management I presume?
Okay, so first, please try to install and run Elixer 2, tap the information button. Keep it or not. Should tell you what you already know (it's a great app). It's over 8 MB, I want to see if it installs ok.
If it installs and uninstalls ok, please do a battery pull, leave it out for 60 seconds.
I'll be here. :)
So i couldnt download that elixer app. When it finished downloading it said "package file is invalid"
Ya I'm rooted and here's a screen shot of what happened when I tried to download it again (i'm to lazy to type it out lol)
Ya I'm rooted and here's a screen shot of what happened when I tried to download it again (in to lazy to type it out lol)
Oh, fantastic!
Please tell me it's been a while since you've been in recovery and wiped cache and Dalvik.
Because here's the thing - both of those areas are used as temp storage to do app installs and the Market/Play Store has been notorious for not always cleaning up after itself.
Now - wiping cache and Dalvik won't always clear that error.
If it doesn't, you most likely have something tangled in /data/data - in other words, where app data are stored.
To fix that, you'll need to do a factory data reset - but because you're rooted, you should be able to throw a full app/data backup (Titanium Backup I presume?), do the FDR from inside recovery, and then restore.
Which backup do you use? Are you comfy with it?
Which recovery? Same question.
PS to staff - even though this has a device-specific root solution, let's please leave this one here as it's a common enough issue and could help others rooted or not, Evo or not. Thanks! :)
Ok well i was in recovery a few days ago to flash the new rom I'm on. The recovery i use is amon ra 2.3 i believe and i use titanium backup. I like them both. And ya i have the terminal emulator installed but idk how to use it (it came pre-installed on the rom)
Terminal Emulator, at prompt, enter df then enter (return, whatever you know) and please get me a screen shot.
Get out of it by saying exit then enter.
Ok - you're allocated over 160 MB of space for the cache and the Dalvik cache - of which, you only have 2 MB free.
That's not enough.
Go into recovery, clear cache and Dalvik cache (amon ra may call that wipe instead of clear, I forget, sorry). You may get a message on startup that Android is rebuilding apps (depends on your version) - if you see that, it's normal.
Do that, try to install Amazon again.
You're not using much of your app space, so it's odd that your cache areas are so full.
In any case, if that works, then you'll want to clear those caches on a fairly regular basis.
You won't lose anything just clearing cache and Dalvik - they're just caches, just like your browser uses. They get built up as you go along to make things run smoother, faster.
Ok to clear them at the first sign of any troubles.
Only thing left then - Titanium Backup, factory data reset, restore from Titanium.
I wonder - are you running apps2sd or anything like that?
That may have some things confused in your space management, not sure.
If you are, I'm too rusty on that, you'll have to ask in the Evo root forum, sorry.
