Ambient light sensor and replacement app recommendations
pedro1977
As its missing an ambient light sensor (ouch) what app would you recommend, really it needs to be something thats customisable and run against the sunrise and sunset times for your location (automatic)
Update: the app called screen adjuster allows you to alter the overall system brightness. The 1% brightness in this phone is an eye burner at night, this app allows you to reduce the brightness for this %. The app advanced brightness allows you to set brightness level via time of day, especially useful at night. Power toggles allows customisation of settings for brightness toggle. The app 2 way brightness w/o auto allows even more toggle options i.e. 10% changes.
