A majority of the devices out there are AMOLED; however, if you recently purchased a new Incredible in the last couple of months, it may be SLCD. To check:
- Remove the battery from the device.
- Underneath the bluetooth and FC icon, you should see "ADR6300VW."
- If you see a "3" at the end (ADR6300VW3) then it is SLCD.
If you do not, then it is AMOLED.
If you purchased your phone new one month ago, there's almost no chance you have AMOLED.
I did and got an AMOLED.
Did you buy it brand new? If so, that store must have had it in stock for a LONG time...I think they switched production over to SLCD back in September or so.
Sure did buy it brand new. I even have all the little plastic wrappings that the chargers come packed in.
