Android 2.1 Software Required
chris1
I am new to the forum, so not sure if this is the right section to post this. I have a Google Android Tablet pc, running on 2.1. I have broken it since purchasing it, and have been looking all over the internet for ways to rectify it, everytime it brings me to here :)
I have bought a Micro SD Card to re install the OS. The only problem is I can't seem to find a working Android 2.1 update.zip link I think it is called, to then put on the SD Card and try to re install.
If anyone could send me a link I would be very grateful, as I would like to get using it again :/
Many thanks,
Chris
Welcome to the Android Forums!
What brand/model Android tablet is it? Google only developed the Android OS running on it...
You would really need the make and model, I'm not sure if there is a generic eclair OS for just "any" tablet. Did you Root it and have something go wrong? You should be able to Clockwork Mod your way out if you had it installed.
