No.Has anyone else had this problem?
No.
Touchdown has been working wonderfully on my Droid X.
Did you try going into applications in the settings menu, going to touchdown, deleting cache and data, and then the nitrodesk folder on the SD card and then uninstalling and reinstalling?
That should certainly give you a clean install of the app.
I assume you are using the newest version as well?
Lex... That seems to have addressed the problem. The entire unit is faster now. Thank you very much!
