Help Android 2.2 - backing up phone
fil_b
Hi all
I have been looking at backing up my Desire so i can put the HTC version of 2.3 on my phone.
I cant find any answers tho
Whats the easyest way to back my phone up? Most of my apps are on my SD card but some will not move
plug in via USB and copy everything? or will an app do it to my pc or sd card?
any advise before i do anything
Thanks
Phil
no its not a root'd phone - i did try that program and it didnt work.
I downloaded app backup and restore and sms backup and i pleased with the little playing i done.
So over the weekend i will back all my phone up and shoe horn 2.3 on my desire
Follow the thread and you'll read on how to get the backup settings - basically they are hidden,
At the end they say that the feature is disabled in Froyo 2.2. You can reach the menu settings, but the actual functionality is gone...
I'd recommend "My backup" too...
