Root Android 2.3.5 ideos x5 u8800 heeeeeelp!!!!!!!?
Timx91
my phone doesnt start, i see only a blue screen!! I cant run the recovery mod! I plugged my phone to pc and the (K) folder (249mb) is empty! I MUST find the boot files!! don't know wtf has happened!! I turned off the phone, I took the battery out, I took the sim out, I placed the battery and then....BLUE SCREEN!!!
You need to calm down and explain exactly what you tried to do and how you did it.
You also need to be sure you didn't try and install the U8800Pro Rom into U8800.
I've found the solution pretty fast, I just put the dload folder from gingerbread 2.3.5 and everything is ok!
I'm sorry for the delayed reply
Hey guys what's up !!!
I need some help if some one can help me out ??
I HAve Ideos X5 u8800 and i want to install oxygen Rom to my Cell i have rooted my cell but when it goes to android system recovery
apply update from sdcard then i choose the zip file of oxygen rom its say's:
finding update package...
opening update package...
verifying update package...
E:failed to verify whole-file-signature
E:signature verification failed
Installation aborted.
How i can install or what does it mean signature verification failed ????
Can anybody help me please
feel free to contact
Thanks
Regards:
TouQeeR
Thanks
Regards:
TouQeeR
Have you tryed what I told you in your thread?
It cant mount sd card, i cant format sd card and now i have blue screen error. By mistake i deleted everything :( I made a file image and put amss.mbn
boot.img
EMMCBOOT.MBN
recovery.img
to in it but still cant oopen phone :( What will i do?
