Help Android 4.0.3 - Galaxy S2 - How to???
dankomba
I want to disable screen animation and effects but in this new version, there seem not to have this option!! I'm so angry, why don't they test and get feedback from people before making UI changes???
can someone help me here? Is there an app or a way to minimise/disable animation effects on Galaxy S2 on this new Android version?
I went ahead and moved this to the GS2 forum so it would get better attention from the most knowledgeable part of the AF community relative to your question. Hope this helps! ;)
Go to Settings>Developer Options> and scroll down - click on "Window animation scale" and select off, and do the same for "Transition animation scale" and there you go - effects gone. ;)
