Njd4
Member
OK, so I'm loving android 4.0.4 no issues since I updated a month or so ago via kies on my unrooted XEU galaxy s2...
Except one...
Only had it twice since I updated...
Browsing net, you tube, play store etc over wifi for an hour or so without issue then you tube started buffering..
Then play store died then lost internet connection..
On going into settings, wifi, advanced, it says Ip address unavailable..
I tried rebooting my phone but it didn't help, I rebooted my router but that didn't help either..
Assuming it was my ISP I logged onto my pc but that connected to internet with no problems..
It doesn't do the obtaining Ip address, connecting, disconnecting cycle like others have had.. it says connected to my wifi and the wifi icon is in the status bar it just won't go online! Page cannot be displayed etc...
The only way to get it back was to turn my phone off for about half an hour and on turning it back on the ip address returned..
This problem happened again tonight (the second time) but the only difference is that I got it back by changing to static Ip address which didn't connect but then changed it back to DHCP and it is now back online as I write this but weirdly advanced settings still states IP address unavailable!?
Any advice appreciated!
Apart from this, 4.0.4 is the most stable release I've had so far!
Thanks.
Except one...
.Thanks.
