jason-567
Requirements: Clockwork Mod Recovery + Skills + A rooted android phone, suck on that IOS users
Please make a recovery image before you start. Just in case
If like me you can not wait for the Jelly Bean to be running Android 4.1 on your HTC Sensation I may have the solution. I have browsed a few websites over the last few days and come across two tutorials to get 4.1.1 working on your sensation with Google Now working with voice functionality.
I am only sharing the solution I have not developed it.
Step 1 - Download the following 2 files.
AOKP ROM
GAPPS
Step 2 - Copy both .ZIP files and paste to your SD card.
Step 3 - Boot into recovery and wipe all data.
Step 4 - Install AOKP rom through the install .zip from SD card method.
Step 5 - Install Gapps through the same method. Reboot and power on.
FOLLOW THE FOLLOWING 2 STEPS TO THE LETTER
Step 6 - After first boot, go to Settings > Performance > Processor and set the minimum CPU frequency to 384 MHz, then tick the option: "Set on boot".
Step 7 - Now, every time the phone boots up (including the first time), go to Settings > Developer options and tick "Disable HW overlays".
If all is working well proceed to Step 8
Step 8 - Download Google Now.
GOOGLE NOW or ALTERNATIVE LINK
Step 9 - Boot into recovery and install Google now using the install .zip method.
You have now completed the Tutorial, Well Done.
Please see below the 2 Links for the origional tutorials I followed.
AOKP ROM
GOOGLE NOW
Please see the following screenshots.
Google Now
http://www.youtube.com/watch?v=pPqliPzHYyc&feature=player_embedded
Please say thanks, it helps. If you have bricked your phone it is not my fault.
AOKP ROM
GAPPS
AOKP ROM
GOOGLE NOW
Google Now
