Android 4.1 on PendoPad 8
Pendopad 8" PNDPP8MT8
ROOT.
Gained root access with bin4ry Root MANY ANDROID!
http://forum.xda-developers.com/showthread.php?t=1886460
For this to work, I had to create adb_usb.ini with these details.
C:\Users\<user>\.android\adb_usb.ini has to be created/edited. You may need to install Android SDK if the folder structure doesn't exist. Put the following details into the file:
# ANDROID 3RD PARTY USB VENDOR ID LIST -- DO NOT EDIT.
# USE 'android update adb' TO GENERATE.
# 1 USB VENDOR ID PER LINE.
0x2207
Android 8" PendoPad 4.1 - Other Android Devices - RootzWiki
ROM DUMP.
To get Boot.img, Recovery.img and System.tar off your tablet, use ROM Dump Index of /romdump
That way if you soft brick your tablet, you can always flash the files back.
DRIVERS & FLASHTOOL.
Google - Rockchip USB Drivers
Google - RKDevelopTool Release Pack v1.37
http://blog.**********.com/index.ph...in-8-driver-rkdeveloptool_v1-37/#.UbpYyZyP3p4
Not sure why the * are there. It should read 'geek buying' without the space.
USB Drivers also available here http://vondroid.com/threads/rockchip-usb-driver-for-windows-2000-xp-vista-7-8.6151/#.UbqTbJyP3p4
RKDevelopTool Release Pack v1.37 also available here http://vondroid.com/threads/rkdeveloptool_release-pack-download.7685/#.UbqRJ5yP3p4
The RKDevelopTool Release Pack will allow you to flash individual files eg. boot.img, recovery.img, system.img, etc.
FLASHMODE.
1. Turn off tablet
2. Plug USB cable into tablet and PC
3. Hold 'Power' and 'Volume -'
4. Load Driver if required
CWM RECOVERY.
Until this device is fully supported, download the 'Generic ramdisk_only image'. Make sure you have a copy of your original boot.img and recovery.img from the ROM DUMP step in case something fails.
CWM-based Recovery images for RK3066 devices | androtab.info
To enter CWM Recovery.
1. Turn off tablet
2. Disconnect from PC (if connected)
3. Hold 'Power' and 'Volume -' or use a reboot to Recovery app http://www.freaktab.com/showthread.php?1050-Reboot-App&highlight=
