Yeah, could be. Over here silly numbers of texts are included in most tarrifs, so that's not an issue for most.
Well Sense doesn't have to look like that either. You can use different clocks, wallpapers, widgets, collect your apps into folders. And if I'm honest I don't think much of the stock android icons, as used in the GPE ROM (I've always thought that phone icon was ugly since ICS was first released).
But that's one of the things about Android - anything you don't like the look of, you can change.![]()
......no alarm when device is off.......
Check your sound profiles under settings if you haven't done so already. Also plug in your headphones and check settings again to see if it mutes the notification sound to protect your hearing. Just like when you have the earphones on and make it too loud it gives you a popup warning on screen..
