Root Android*admirer^rom^android*lithium 2.0
andriodadmirer
ANDROID+ADMIRER ROM
LITHIUM 2.0
CHANGES..
*DEODEXED
*ZIPALIGNED
*INIT.D SUPPORT
*EXT 4 SUPPORT
*CHANGED BOOT ANIMATION
*CHANGED SHUTDOWN ANIMATION
*NEW THEME USING UOT KITCHEN( THANKS UOT!)
*CHANGED MIUI PLAYER TO STOCK MOTOROLA "CONNECTED MUSIC PLAYER(COMES WITH SHOUTCAST RADIO)
*REPLACED LAUNCHER WITH HOME++ LAUNCHER
*REPLACED STOCK 3D GALLERY WITH STOCK MIUI GALLERY
*THIS ROM HAS OFFICALLY BEEN "PIMPED" WITH EXTRA TWEAKS USING PIMP MY ROM(THANKS P.M.R)
*INSTALLED ADOBE FLASH PLAYER 11
INSTALL INFO
*ONLY FLASH THROUGH CWM 5.0.2.8
*DOWNLOAD ZIP BELOW
*BOOT INTO RECOVERY
*WIPE DATA
*GO TO MOUNTS AND STORAGE AND SELECT FORMAT SYSTEM
* GO TO INSTALL FROM SD AND SELECT ZIP
*AFTER IT INSTALLS GO TO REBOOT NOW AND IT SHOULD BE GOOD TO GO
its late ill post screen shots tomarrow
AndroidLithium2.0.zip download - 2shared
My little review of Android*Lithium:
In exact order of thought.
*Boot animation is nice
*Has a Admired Monster 5.3 feel after boot animation
*Really dislike the launcher
*Noticed its based off the 2.3.6 update
*Screen Animations will drain battery like my AWO, BUT it seems smoother...
*When in some menus, the text is colored gray, which makes it unable to be seen (Not major, in fact, I think thats common on UOT'ed roms)
*Wifi connects fast...
*Adobe Flash didn't seem to work on the desktop version of youtube and miniclip
*Sweet background :)
Over all, Its a nice rom, however, because of the launcher and some other little things, I will stick to AWO :)
Good job android admirer :D
Good job admirer
Ran this and saw that it was a ok rom...
I really dislike flash player (reason it doesn't make sense to have while it doesn't even work for most people, just a insider thought) and as 2Gb said the animations drains battery, aside from that its an ok rom, I like the look and feel of it, its very nice of you to use 2.3.6 ..
Keep up the good work.
the desktop verison of Youtube doesnt require Flash Player, If you really want to have player then if would be better to uninstall it from the rom and then go about the process of installing it via the long process of those libs files lol its also a huge memory killer but a good website to check if flash is working is Veetle.com
This rom works perfect on my phone compared to the other roms I have installed...Lithium 1 worked really good and this one works just as great...the reason I don't give it a full ten is because of the home launcher but I use Adw instead and I also have my own theme that changes the colors and status bar icons...but overall its a pretty great rom
Misfit toy makers. Its like outta the woodwork. I like this work. Impressive jump over your last release. only grab your pngs from uot if you want but otherwise stay off it. Youll do better by learning it yourself and through guides. You know i onced owned that hat on frostys head. Size to big. Tisk. Tisk.
