Help Android boot loop
jagat
i got juicydefender addon from a friends sd card...i install addon...but when i lauch it , it says this is addon u need app..so i dload app from market...after install..reboot loop continues...from lg screen at startup...plz help...i juss got this phone...and it's useless now
I had the same problem with juicedefender ultimate. I just factory reset my phone and started over again. Juice defender plus didn't have this problem. I think you can go to safe mode and delete the program.
i'm sorry...i m complete newb from windows mobile......how do i go in safemode and delete program? also battery is completly discharged...
I did a factory reset using the following
  1. Turn the power off.
  2. Hold the Home and Volume Down button
  3. Press and hold the Power button until the device turns on
  4. Follow the on-screen instructions to reset your device
All data including third-party applications will be deleted from the LG Optimus V. Once the wipe is complete, the phone will reboot to its factory fresh state.
List of button combinations:
Boot into Recovery:
  1. Power off.
  2. Hold the Home Button, Volume Down Button, and the Power Button at the same time.
  3. Release when you first see the LG logo.
Boot into Emergency Mode:
  1. Power off.
  2. Plug in the USB cable and wait for the charging screen to come on.
  3. Hold the Return Button, Volume Down Button, and the Power Button at the same time.
  4. Release when you first see the LG logo.
Boot into Safe Mode:
  1. Power off.
  2. Hold the Menu Button and the Power Button at the same time.
  3. Release only after ALL of the boot animations have finished.
  4. You should see "Safe Mode" in the lower left corner of the screen.
Manually Reboot:
  1. Hold the Volume Up Button, and the Power Button at the same time for 10 seconds.
  2. The volume will increase while you do this.
List of Recent Apps:
  1. Hold down the Home Button.
  • Like
Reactions: tli
