Android Command Center 6 - ADB Shell with a GUI!
sandix
Android Command Center 6 is a simple Windows application to interface between Windows and your Android Device. Compatibility is limited to Android 4.0 and up. Rooted users should be very careful while using the application. Some features may not work with all phones.
I have been working on this application since early 2013, and it has come a long way since I started this project, and it is still getting constant updates, and bug fixes!
Enjoy the ease of using a GUI to run your everyday commands.
There is also an option to install ADB into your system root which allows you to access ADB Shell from anywhere in the computer.
Let me know what you guys think!
Android Command Center 6 - URGERO.ORG
