android dummy
i need help desperate,,,,,i went to settings on my tablet,,vimicro android 4.2...lg i think,,,,in settings back up.reset,,i hit that,dummy me not waring my glasses and did nt read good enough what it would do ,,,i hit reset and i think delete data or go to factory reset or something,,,now when i turn my tablet on i get no connection to wifi,a black screen with a round circle with + thru and it moves into the corners when i hit it ,at the bottom i have my return arrow,and the 2 following icons and then the 3 uppoints which stands for go to settings,,,my clock stays on 8.02 what happened and if i delete everything can i get it back o how can i start to load software for wifi,google and so on again,,
please anybody......help
Some times not always, their is a small pinhole in the decice, us a paperclip to push in the button inside the hole, does a reset. Look on the back of the device towards the top.
Welcome to AF by the way!!!
When you first got your tablet did someone else help set it up for you, with the WiFi password, Google account details etc.? Because it would have been at factory defaults when you first got it. And when you hit the reset it went back to those factory defaults everything got deleted, and so things like WiFi password and Google account would have to be re-entered. The clock would be wrong after a reset as well, until it's corrected either from the internet or manually.
