I've got the China Tablet and i get the error "The Process Android.Process.Acore has Stopped Unexpectedly. Please Try Again"
Andriod Version 1.6
Kernal Version 2.6.29
WMT SDK Version 1.9.
I would like the repair this tablet ...what should i do .
Your best bet for the answer to your problem would to be to check in with the users of your device. Just click into the sub forum for your device and ask your question there. Here is a link to the list of tablets: Android Tablets & MIDs - Android Forums Best of luck to you and thanks for taking the time to say hello.
Andriod Version 1.6
I did a little searching on this, but there does not seem to be a single solution / answer that can explain this. You're probably past the point where you can simply undo whatever it was that you last did, eh?
Anyway, a Google search of your error does return a lot of results with people having the same issue as you, but I would be remiss to recommend a particular path to take given how nebulous this issue appears to be.
