Root Android ID Changer
Goodeye
Android ID Changer
So what does this fully do exactly? I know it allows you to change your android ID back to the original due to I guess how some ROMS will give you a deaulft (ie not your original) Android ID.
From what I found on it, apparently it will allow you to get all your marketplace downloads back in the "My apps" section when you get the new rom all set up.
Is this correct? Is this a sure fire way to do it? I went to a Cognition rom and it worked like a dream (other than a battery issue) problem was none of my apps free or paid showed up in the "My apps" section of the marketplace after the rom change. I went back to stock with ODIN and same thing none of the original, nor the apps from when I was on the ROM were there.
Im kinda wanting to go back to another 2.2 (Axura 2.1 with the black theme) to be on 2.2 after watching a buddy with it on his captivate. I just dont wanna lose the access to apps again, and having to pay for ones I already paid for.
