Help Android Incredible by Verizon Wireless
How do you move saved photos on the hard drive to the SD card for the droid incredible original? I have about 180 saved photo's on my hard drive and need to move them to the SD card that I have.
First, the phone doesn't have a hard drive, it has flash memory. Second, you can use a file manager app like Astro, or you can just connect it to a pc, and put the phone in Disk Drive mode and do it from there.
Goto Settings > Connect to PC > and check on Ask Me.
Plug in your phone to your computer using the USB plug. When prompted on your phone, select mount hard drive. Then on your computer, find your phone either under my computer on Windows, or a your desktop for a Mac.
Then using the explorer, locate the pics and click and drag to move the pictures just like you would any other normal files.
