Help Android keyboard question..
devgala
Is it just me or has anyone else noticed that when using the android keyboard when I go to insert a Smiley ill hit menu and sometimes there's an option that says "insert Smiley" but most of the time it says "insert text" in its place on the bottom of the menu in the middle.
Maybe i was in a different application and the menu was different from when I use it in texting..
But does anyone know if there is a way to change the menu in the messaging app to have insert Smiley instead of insert text so I don't have to hit menu > more > insert Smiley. I hate the auto correct when I go to insert ":" and it moves it a space back to the end of the last word...
I tried searching all over for an answer with no luck, sorry if its been asked before! Thanks :-)
Using android keyboard, you can insert a smiley by hitting the menu button > More > Insert smiley.
Hope this helps?
