blaxican25
Android Expert
just posted in case anyone wants the new android market 3.0 it works on the cm7 beta
use root explorer to move it from your sd card to system/app, you can save the existing vending.apk in case you need it later so paste the new vending apk into system/app and install then boot into recovery wipe cache and delvik cache then reboot should be working.
http://www.youtube.com/watch?v=5Pbo-d62ivY&feature=player_embedded
vending.apk
vending.apk
