Help Android Market error (authentication required)
tuggy24g
Well I am at a dead end right now. I am not sure what to do at this point. When ever I go to access the android market on the tablet it tells me that I need to authentication require in order to access. I did delete my account and add it again. Still nothing. I tried going into gmail and fooling around in there. No go. Now my only option at the moment is to factory data reset and not what I want to do. Also this is not rooted or have any custom roms on it. Just all stock with a few apps on it. Thank you for your time
Brad
Just curious, can you log in to the web version of the market? https://market.android.com/
And if so, can you see your Xoom under devices when you go to install something?
Of course, you can't update apps through the web-based market, but that might provide a clue as to what exactly is broken.
Well I did a factory restore and fixed the problem. So now I have to start from scratch all over again ugg!! Anyway thanks for the help!
Download Appbrain from market. I learnt the hard way with my HD2 and multiple rom installs. i hated having to find and dl all the apps everytime i flashed a new rom.
Brad[/QU
I have Acer iconatab. I fixed it by clearing out the proxy when I exited from pdanet tablet application. Run the application, select the clear proxy button, hit the backspace button, then select the clear proxy button again. You will actually see the proxy settings the second time, select clear,save. No need to hard reset. Good luck.
Thanks for the suggestion, but I already did a factory reset. I did not know about any proxy reset or anything of the nature. If it happens again (god hope not) then I will try your way.
I had the same issue -> It resolved after a while and turned out to be a GRPS connection error. I DIDN't even clear the market's cache.
