Android Market Log In Problem..
DFRESH
It started last night...
Can't Established a reliable data connection to the server.
This could be a temporary problem or your SIM card may not be provisioned for data services. If it continues, call costumer care.
Any of you experienced the same prob? If so, how did you solve it? :confused:
Geez! this problem needs to be fixed!
I had to reset my HTC Hero Sprint to manufacture settings and it fixed the problem.
So if any of you ever have this problem, you will need to do the same.
