Try clear cache and clear data in Settings for the Market app.
Have done that more than once yesterday it kept boot looping me.
also uninstalled all market updates it downgraded the market but i still had the same problem.
In order to install the newer vending.apk I don't need to force uninstall with titanium?
No good just clearing cache on phone, started doing updates of everything. it installed marvel comics update then bootlooped again. didn't finish 3 other updates. Actually that failed too it still says it needs an update.
might try the cwm cache clear. that does wipe anything important? what about dalvik cache?
So weird because it acts and feels normal but right before finishing an app install it reboots me.
Is there a way to reinstall android market from .apk on cm7?
I can no longer install anything from market or i get rebooted.
Or maybe just reflashing gapps?
Need assistance.
Problem is that backup prob corrupted. If I have reflash this time I will install all apps from market. Back up Rom first then restore backup. Didn't realize how much trouble a bad restore was. Even if gapps flash by itself fails. It prob won't brick me correct?
When it happened to me, I just went into CWM and did all the wipes/formats and flashed again, but I still used TB to restore my apps, and it's been fine ever since, so I don't know what caused the problem. Maybe just restore the apps without data. Even if it doesn't work it's worth a try before you go through downloading 50 apps from the market.Problem is that backup prob corrupted. If I have reflash this time I will install all apps from market. Back up Rom first then restore backup. Didn't realize how much trouble a bad restore was. Even if gapps flash by itself fails. It prob won't brick me correct?
