Android market
Is anyone else having problems downloading from the android market.I am trying to download some new apps and update some older ones but all I get is "starting download" never gets any further.This happens if i use either the wifi or the mobile signal.
just found the solution its because I changed googlemail to gmail just been on googlemail and changed it back now my apps can be downloaded
im a newbie too so im not sure but i searched some of the other forums and found out the googlemail thing solved it.Im sure one of the learned ones on here could explain it perhaps
