Help android media programs not recognizing sd card
maish
Hi ( I am a new Captivate convert - from blackberry) and trying to find my way through
My sd card ( 32 gig kingston) is recognized by windows ( when attached to usb) and recognized by astro file reader , and winamp etc.
yet the built in voice recorder and video player will not run and I get erroro message
Your phone does not have an SD card inserted
I didnt format the card originally since the phone recognized the card without it
I also disabled the scan at startup with a program startup manager
is that the problem ?
thank you for your patience with a newbie
Why did you disable the startup scan? You shouldn't be using task killers and such if you don't know what you're doing. It's akin to randomly ripping out wires and hoses from your car's engine compartment because you don't like the clutter.
First thing to do is not sabotage system processes like that.
Second, make sure both your internal and external SD cards are mounted (yes, it's possible to "unmount" the internal SD).
Third, try backing up your data and reformatting the card, in the device.
Also possible you have a bad card. Kingston is only mediocre-quality, a tiny notch above SanDisk.
sremick
thank you for your help
after following your advice it seems that
1) the card is fine
2) since scanning media is disabled upon startup the card isnt recognized
the way I fix it currently is unmounting the card and remounting which forces a media scan and then my external sd is read
how to i re-enable a media scan upon initial bootup ?
through the app "startup manager" i disabled media scanning at startup
I do not have an option through "startup manager" to re-enable it
here is the web site I followed if anyone is interested
How to disable media scan on Samsung Galaxy S | adeck.us
the suggested app "scan media" does notmake my external sd "readable"
does anyone have an idea how tore-enable media scan from the startup
thank you
can anyone give me a hand here
basically i used startup manager to disable media scanning when the phone boots
i dont see a method for re-enabling
if my media isnt scanned the phone doesnt recognize the external sd card
thank you
idk if u figured this out or not, but i had the same issue an came across a app called "rescan media root" for root users..It gives you the option to re enable media scanning, worked perfect for me
