Seclusioned
Boost galaxy s2. Had for about a year and a half and I have 2.5 gigs a month. Its unlimited but boost throttles you after that.
I have never had an issue untill 3 months ago. I hit my 2.5gigs in 2 weeks and then it got soo bad I couldnt even load pandora. I have seen 100s of threads on this topic with androids and ICS. All say the same thing. Disable sync. Limit background data. Blah blah blah. I dont use sync. Ive always had it off. I dont watch youtube videos and never update youtube. I have done everything i can including disabling everything I possibly can in applications including anything google.. I have disabled google play google services google framework. I have checked the box at "do not keep activites" and no background process at limit background processes. I factory wiped my phone yesterday. And only have pandora on it. I should bot have to do this. I have never had the issue.
Someone tell me something new. Im not "phone tech smart" but know my way around any pc. Ive never rooted or modded a phone but if it will fix it, ill try it.. Can provide screenshots if needed.
Edit
Android os used 75mb in 12 hours while sitting on the table. In 3 hours its ran 260mb on wifi. :/
Thanks
Edit
Thanks
