Help android.process.acore, and many more same force close at same time
my desire hd works very well for 2 months from purchase.
every one is praising the developers.me too.
but from yesterday, it shows every application stopped working.
i instlled so many ~50 applications on my mobile, which are okay according to me.
i rebooted, factory restored, changed sim, kept set open, opened battery ...nothing worked.....
when th phone remans turned off for 1 hour, it works for 1 works hour normally.
i don't know what to do.
please help me.
i can't tell my parents about it.
and cannot afford the amount spent on servicing.
what are the possible solutions.
problems are: android.process.acore , android.goolgle.locations, android. 100 of others. i even can't turn off my phone.
Always include:
Device: htc desire hd
Carrier:
Country / Language:
OS / Browser / build number (if applicable):2.2
A quick google of the android.process.acore error message shows that the similar error message could be tied in to sync settings. Have you tried turning autosync off? Can you get that far?
