android.process.acore error msg
  • Start date Start date
A
Android Question
Guest
I've seen this posted a few times. Tried the removing of fb, deleting data of contacts, contacts storage. Install my ROM clean.
For me it starts immediately after a restore from titanium. The restore is an app only restore, no data - and I don't restore fb or fb messenger. And I am not installing fb or fb messenger and the error keeps occurring. Also I am NOT restoring any system apps or data. Just user apps.
So my question is - is there ANY way to find out which of my restored user apps is causing the error message?
Any help would be greatly appreciated as I have more than 300 user apps and really don't want tontest 1 by 1.
Best bet might be a logcat. If you can pin the timing of the error to an app process, you may be able to identify it. If you are using a logcat app for this, last I checked you'll need to convert it to a system app via TiBu prior to using it or the output will be incomplete. Otherwise you can try adb logcat.
