Help Android SMS absolute path.
h3h
Hello, I have been searching for the absolute path of where my Android Epic 4G stores SMS. I want to dump them to my comp "without" using an app. I'm using Syndicate ROM froyo. Thanks!
I found it btw.
/data/data/com.android.providers/telephony/databases/mmssms.db
You can then use SQL Lite Viewer to properly view the sms db.
