Apps (Android Studio)-Connecting to a bluetooth device and receiving data
I am Currently building an application using android studio. So far i managed to get the app to turn on the bluetooth and search for devices, but i still can't figure out how to connect to a my device.
This my connection.java code
Code:
        import android.app.Activity;
        import android.bluetooth.BluetoothAdapter;
        import android.bluetooth.BluetoothDevice;
        import android.content.Intent;
        import android.os.Bundle;
        import android.support.v7.app.AppCompatActivity;
        import android.view.View;
        import android.widget.ArrayAdapter;
        import android.widget.Button;
        import android.widget.ListView;
        import android.widget.Toast;
        import java.util.ArrayList;
        import java.util.Set;
public class connection extends AppCompatActivity  {
    Button b1,b2,b3,b4;
    private BluetoothAdapter BA;
    private Set<BluetoothDevice>pairedDevices;
    ListView lv;
    [USER=1021285]@override[/USER]
        setContentView(R.layout.activity_connection);
             b1 = (Button)findViewById(R.id.button);
             b2=(Button)findViewById(R.id.button2);
             b3=(Button)findViewById(R.id.button3);
             b4=(Button)findViewById(R.id.button4);
             BA = BluetoothAdapter.getDefaultAdapter();
             lv = (ListView)findViewById(R.id.listView);
    public void on(View v){
        if (!BA.isEnabled()) {
            Intent turnOn = new Intent(BluetoothAdapter.ACTION_REQUEST_ENABLE);
            startActivityForResult(turnOn, 0);
            Toast.makeText(getApplicationContext(), "Turned on",Toast.LENGTH_LONG).show();
        } else {
            Toast.makeText(getApplicationContext(), "Already on", Toast.LENGTH_LONG).show();
    public void off(View v){
    if (BA.disable());
        Toast.makeText(getApplicationContext(), "Turned off" ,Toast.LENGTH_LONG).show();
    public  void visible(View v){
        Intent getVisible = new Intent(BluetoothAdapter.ACTION_REQUEST_DISCOVERABLE);
        startActivityForResult(getVisible, 0);
    public void list(View v){
        pairedDevices = BA.getBondedDevices();
        ArrayList list = new ArrayList();
        for(BluetoothDevice bt : pairedDevices) list.add(bt.getName());
        Toast.makeText(getApplicationContext(), "Showing Paired Devices",Toast.LENGTH_SHORT).show();
        final ArrayAdapter adapter = new  ArrayAdapter(this,android.R.layout.simple_list_item_1, list);
        lv.setAdapter(adapter);
And Also that's my activity_connection.xml code
<?xml version="1.0" encoding="utf-8"?>
<RelativeLayout
    xmlns:android="http://schemas.android.com/apk/res/android"
    xmlns:tools="http://schemas.android.com/tools"
    android:layout_height="match_parent"
    android:paddingLeft="@dimen/activity_horizontal_margin"
    android:paddingRight="@dimen/activity_horizontal_margin"
    android:paddingTop="@dimen/activity_vertical_margin"
    android:paddingBottom="@dimen/activity_vertical_margin"
    <TextView android:text="Connect to TANGO"
        android:layout_width="wrap_content"
        android:layout_height="wrap_content"
        android:id="@+id/textview"
        android:textSize="30dp"
        android:layout_alignParentTop="true"
        android:layout_centerHorizontal="true"
        android:textColor="#0d0d0d"
        android:textStyle="normal" />
    <ImageView
        android:id="@+id/imageView"
        android:layout_below="@+id/textView"
        android:theme="[USER=19691]@Style[/USER]/Base.TextAppearance.AppCompat" />
    <Button
        android:text="Turn On"
        android:id="@+id/button"
        android:clickable="true"
        android:eek:nClick="on"
        android:layout_alignBottom="@+id/button3"
        android:layout_alignParentLeft="true"
        android:layout_alignParentStart="true"
        android:background="@color/but"
        android:textColor="#ffffff" />
    <Button
        android:text="Get visible"
        android:eek:nClick="visible"
        android:id="@+id/button2"
        android:layout_alignBottom="@+id/button4"
        android:layout_alignParentRight="true"
        android:layout_alignParentEnd="true"
    <Button
        android:text="List devices"
        android:eek:nClick="list"
        android:id="@+id/button3"
        android:layout_below="@+id/textview"
        android:layout_toEndOf="@+id/textView2"
        android:layout_marginTop="49dp"
        android:layout_alignLeft="@+id/button2"
        android:layout_alignStart="@+id/button2"
        android:textColorHighlight="#ffffff"
    <Button
        android:text="turn off"
        android:eek:nClick="off"
        android:id="@+id/button4"
        android:layout_below="@+id/button"
    <ListView
        android:id="@+id/listView"
        android:layout_marginTop="39dp"
        android:layout_below="@+id/textView2"
        android:layout_alignParentEnd="true" />
    <TextView
        android:text="Paired devices:"
        android:id="@+id/textView2"
        android:textColor="#276ddd"
        android:textSize="25dp"
        android:layout_centerVertical="true"
        android:layout_toRightOf="@+id/button4"
        android:layout_toEndOf="@+id/button4" />
</RelativeLayout>
If anyone can give me some tips, that'll be great.
