Android system battery hog?
Pedro7
been having problems lately with my battery performance. im finding that the battery is being used by the android system (96%) even when the phone is on standby through the night. before it used to change to phone idle and cell standby having a high percentage with the android system staying very low, but now the battery is being eaten alive by the android system and the battery is draining rapidly.. i used to get 2 days out of my battery before it needed charging but now im lucky to get just over a day..
help! :eek:
Sounds like you got something constantly running/updating, make sure your email is not checking too often or switch off & check manually.
Do the same with the weather app, also check your calender is not syncing to often
all of the auto sync processes are off.. everything is set to manual update.. this is killing my battery :(
