Android System Info app.
bosshog
Member
Trying this app out, and i must say it's a good one, Show's you everything phone log, how you cpu is doing the lot, what's draining your batt.
Does this work on Ice Cream Sandwich? Currently it is not giving me the option to select a log category...
It should work fine, but some of the older reviews did mention something about the need for ICS compatibility updates, the multitouch tester being inoperative or something. The last update was October 2011, so who knows. I was wondering if this app is considered a task killer...?
