Yeah, that's pretty bad. Has your battery life always been that bad?
You can try roam control to force your phone to roam, and not spend so much time searching for a signal. It should save you some battery life, but watch how much data you use when you do that.
This is roam control. Even though you have an unlimited data plan, you probably still have a limit of how much data you can use while roaming.
300mb, sprint can/will either charge or discontinue your service if you go crazy over.
