Root Android system recovery utility problem
Wanderlei
Hi all
Following the big guide and im at the nanroid backup stage in the recovery utility
Ive got
Android system recovery utlity
Use trackball to highlight, click to select.
options:
reboot system now [home+back]
apply sdcard:update.zip [alt+s]
wipe data/factory reset [alt+w]
Then at the bottom it says
E: Cant open /cache/recovery/command
Thats the full screen, nothing about backup/restore :S
My recovery screen looks like:
-Reeboot system now
-USB-MS toggle
-Backup/Restore
-Flash zip from sdcard
-Wipe
-Partition sdcard
-Other
-Power off
IAt the bottom
Build : RA-hero-v1.6.2
It looks like your recovery image is not the Amron RA one, you need to get back into your Phone, run flash rec and follow that procedure again.. Hopefully that will help
