Root Android System Recovery
LukeOlson
To enter the Android System Recovery mode, follow these steps:
  1. Turn the device off.
  2. Press the Volume Up Key and then press the Power/Lock Key at the same time until the device switches on. (Tip: Volume Up is the end closest to the Power/Lock Key.)
  3. Once the SAMSUNG logo appears, release the Power/Lock key while continuing to press the Volume Up key.
  4. Continue to press the Volume Up key until the Android system recovery screen displays.
  5. Release the Volume Up key.
Sorry for this reply cuz I don't have a galaxy s , but i have another device , a low cost one, and it turned off while the fw was updating and now it won't turn on.if it is a made in china tab does it means that there's no recovery mode or bootloader on it cuz no matter what/how i try , it doesn't start.?
