Android system using sensor
ekyle
Android Expert
Lately when I check Spare Parts my Android System sensor usage is at 100%, not the ~10% it used to be. I can't figure out what is using it... I do know that it us causing some serious drain on the battery.
Sent from my Eris using Tapatalk
have you check the battary to see what it is using. settings>> about phone>> battery usage. Pretty sure thats the location of it. If not its somewhere in settings.
No apps were open. It had been going on for awhile. I just sucked it up and did a factory reset. First one since I received the OTA. It is running the best it has in awhile.
