Root Android Terminal Emulator capitalizes the letter "i"
New to rooting but I've successfully done it to my Optimus M then to the Samsung Admire. I used Android Terminal Emulator to uninstall or delete the apps that came on the phone for the Optimus but when doing it on the Admire my main problem is whenever I put a lower case i it capitalizes itself so I'm stuck and would greatly appreciate help. Also, I tried deleting and re-installing Terminal Emulator, no luck. :(
I'd you wanna delete apps use titanium Backup or root explorer
I've tried those but it says error and it can't uninstall or delete.
I used the Android Terminal Emulator once and i had a the same issue but i could easily change the capitalizing with the keyboard. if you are rooted then you should be able to use TiBu to debloat, i didnt use it when i did though. look up Root Uninstaller
good night
Somebody can help me?
the problem is as follows:
was wanting to install a CFW on my Samsung SCH-R720 but it tore me to want to upgrade to 2.3.6 dierror me and now I get the Firmware upgrade screen Encountered .. Error please try again but no longer do.
some solution?
thanks for everything :confused::confused::confused:
I've tried root uninstaller, linux, titanium backup, super aToolbox, android terminal emulator, better terminal emulator, Astro manager, deleting it via usb connection, and a few other things I can't even remember. Is there a way to fix android terminal emulator? I deleted it and re-installed it, no luck. I type it in lower case but as soon as I hit the next letter it changes. Is it a lost cause?
