Root Android Themes
Hi all. I just rooted and modded my LGoptimusV using this very helpful thread http://androidforums.com/optimus-v-...-how-simplified-root-recovery-custom-rom.html
I am using the Green Machine Theme which is great! But I was wondering if there are many other themes and where I might find a list or something.
Does one size fit all when it comes to android themes or do I have to look at compatability when it comes to choosing themes?
Thanks
- zurke
You can start by clicking on my signature ... you will find many awesome themes + boot animations and much more, they also take requests.
If you put the backside rom on your phone, you can download their themes straight to your theme chooser app in your app drawer, which makes it so easy and they're free.
Check it out!!! Some screenshots from purple haze theme, disregard the other photos ...http://androidforums.com/members/badblue1-albums-screenshots.html
I have searched and cannot find a "theme chooser app" installed. Should that have come with BACKside?
- zurke
Yes, when you open your app drawer you should see it, it should be a different colored android guy and say theme chooser below it.
