Help Android & Touble Twist
eskay
I heard that double twist could take my itunes songs and put it on my Droid. I downloaded it and I see it on my pc but how do I sync it with the Droid?
Try this instead...
1). Download sharepod and use it to copy your songs to your PC.
2). Then hook up your phone via USB to your PC.
3). Create a folder on your SD card called music if you haven't already done so.
4). Then copy your music to your phone's music folder.
This is SO much faster than syncing with software. The DT software took so long, I uninstalled it.
